0 members (), 1,191 guests, and 7 robots.
Page 1 of 5 1 2 3 4 5
#110222 03/08/06 02:26 PM
Trumpy Offline OP
Would anyone care to comment on what this contraption might be?.
This pic has been in my computer for some time now and I've forgotten who exactly sent it to me.
Here it is:
#110223 03/08/06 04:05 PM
PVC with ABS cement. Gawd.
#110224 03/08/06 04:15 PM
I am not the one who sent you the picture but it appears to be an electric shower head.
I did a quick Google image search and found an expired link on EBay for one that looked close to this. The wires are for a heating element in the head and the small line coming out of the face ring is for a hand held nozzle.
#110225 03/08/06 07:22 PM
That's the latest in capital punshinment.That way you die clean.
#110226 03/08/06 07:33 PM
Trumpy Offline OP
Yeah,
I can see a green wire there, exitting(sp?) the head itself, but there doesn't appear to be a corresponding ground wire with the "supply wiring".
Imagine a thing like this coming to pieces during your morning shower?.
#110227 03/08/06 08:06 PM
I had a little more time to look into this after dinner and I found one company that makes these in Brazil.
Here is a link to the showerhead with the tech specs. http://www.lorenzetti.com.br/ing/blinducha.htm
There appears to be an optional covered pipe from the wall to the head to route the wires in to keep them from getting exposed.
The tech specs say its compatable with a Residual Current Device which I guess is another name for a GFI.
#110228 03/08/06 08:17 PM
An electric shower head??? Electric heater in the head???
Those words " electric shower head" should not be in the same sentence! I do not think I would trust one no matter who makes it, let alone one that was installed like that!...
Personally I prefer heat for my shower supplied from a water heater, and if I need a good "lift" in the morning I will stick to a good cup of coffee!!
#110229 03/08/06 08:38 PM
Thats not ABS cement on fittings, ABS cement is black, might be a " all purpose" PVC and ABS type.
#110230 03/08/06 09:53 PM
Trumpy Offline OP
Well then, it gets worse too.
At least it does according to JamesS:
Funny that you should post that picture as I have just tracked down another shot of almost the same thing taken by a friend of mine while visiting central Mexico. He used this shower for several days and managed to survive, but I'd rather go dirty (or at least limit myself to cold water!)
Thanks James. [Linked Image]
#110231 03/08/06 09:54 PM
Trumpy Offline OP
Just a word to the wise here.
Nasty comments about Mexicans will be deleted.
