0 members (), 1,131 guests, and 13 robots.
#108760 11/19/03 12:33 AM
How about pipe fill, and bending radius? I cannot see how either can be complied with.
Pierre
Pierre Belarge
#108761 11/19/03 06:34 AM
a valid Q GETELECTRIC...
what is the dif bettween this raceway , amd all the wells out there running conductors in wellpipe?
myself, i don't go off on a rating/listing jingle anymore, i simply tell people that a raceway should identify itself as to it's contents...
#108762 11/19/03 08:15 AM
There's a product made for copper that's a "cold solder", made for repair work. It doesn't require a torch.
None of the plumbers I know would ever use the stuff, but it's just possible that that's what was used to get that 90 on...S
#108763 11/19/03 11:49 AM
Instead of the "water pipe", wouldn't a reasonable solution be containing UF romex in {notched} wood molding up the side of the pole?
#108764 11/26/03 11:56 PM
According to the NEC, 3/4" conduit can't have a radius tighter than 4 1/2 inches using one shot or full shoe benders, and "other bends" can't be tighter than 5 inches. See NEC 358.24 and table 344.24.
#108765 11/27/03 12:02 AM
And another thing. According to 358.6, it says "EMT, factory elbows, and associated fittings shall be listed." I doubt if copper tubing with sharp 90s would be considered listed for that use.
Also, according to 358.2, it says "EMT is generally made of steel (ferrous) with protective coatings or aluminum (nonferrous)." It doesn't say copper can't be used in that article.
#108766 11/27/03 01:03 PM
shame to anyone who would chastise this work going by what we see in the picture. those of you who haven,t done anything that compares to this interms of code violation are either full of s... or have an halo for a hard hat.
#108767 02/24/04 01:17 AM
In this installation, I probably would've gone with schedule 80 & a PVC LB(sunlight resistant) for resistance to the elements & possible impace damage... As for aesthetics... A simple coat of spray paint before installation to match the pole [Linked Image]
#108768 02/26/04 07:54 PM
Could these lamps be low voltage?
