AE-Gifts, Affordable Everyday
0 members (), 618 guests, and 6 robots.
Page 3 of 3 1 2 3
Z
Hello folks.
I work in IT, but working in IT frequently involves coming up with power solutions, so I have interest in electrical work as well.
There are a lot of situations where an installation of equipment will only be around for 6-12 months, and the equipment doesn't draw very much power. In these situations, it would be extremely wasteful to call an electrician out to install additional outlets which will be completely unused once the installation is gone.
We use power strips all the time where I work, but we try to use them as safely as possible. We use only high quality strips, and we never daisy-chain. When I do find daisy chained strips, I fix it and chew out whoever is responsible.
I never understood the "rule" about not being able to secure power strips to a surface. In a lot of cases, securing them to a surface makes for a much neater installation than having them loose on the floor to become hopelessly tangled up in a dangerous, potentially firey mess.
What's better: three power strips secured to a table leg, up off the floor, with the cables neatly secured, or a big spaghetti mess on the floor that frequently gets kicked and/or jostled by people working in the area?
This is definitely a case where the code can probably use some adjustment. Though I fully agree that the photo in this post is much too messy and the daisy-chaining needs to be fixed!
-Z
I Don't have a problem with "surge strips" for the most part all of them have a built in circuit breaker. Thats all I need. The Wiring IS protected!
Where is the problem if the surge strip has a circuit breaker? I know code says that it is a No-No, But Why? Without these surge strips you would see alot more scary wiring!
We have more important issues to deal with.
Let's put things into perspective.
I wish the only violation here was 110.12 neat and workmanlike manner
Justin
It's Not The Fall That Kills You...
It's That Sudden Stop At The End
Very nice work Larry!
Your solution works well in an "entertainment center" closet but if you don't mind me asking how you do explain to a customer you need to install 12 receptacles in their home office/former bedroom?
Wait a minute! I see a fifth power strip to the right in the first photo.
Nice organized job Larry, at least compared to the first picture.
Ian A.
Page 3 of 3 1 2 3
