0 members (), 875 guests, and 18 robots.
Search for "Meter Mounting Equipment" see PJSR.GuideInfo
http://database.ul.com/cgi-bin/XYV/template/LISEXT/1FRAME/ccnsrch.html
I found the answer to my question, just as I suspected!
Wire connectors in Listed meter mounting equipment are intended to accommodate one conductor only unless use with more than one conductor is clearly indicated on the wiring diagram or other readily visible location.
I still don't see how you can claim a violation without removing the cover.
This, odly enough, is a photo of the service on my duplex. It is a typical example of an earlier Reno service.
While today things are done differently, I can't believe that the entire trade, in the whole town, once "did it wrong." I suspect that the rules have changed.
If nothing else, much larger wires are now used, and the 60 amp meter sockets shown are not allowed.
Picture submitted by renosteinke
Trumpy
Why two meters for each apt.
Rob
F
Rob:
in few apt complex they use the second meter for waterheater but some case and i say some case they used that for electric baseboard heating too but really honestly for many years went by most poco disconuted the off peak rate meter now if they use the off peak meter useally a specal electronic meter and most meter i do see it here have electronic meter it can send the singal thru the radio waves or thru the power lines i am not sure which is which they used that and they can pinpoint the peak reading the same thing with commercal metering too it work the same way too
merci , marc
Just love that asbestos cement siding.
Rob,
You'd have to ask renosteinke about that one, I only posted the pic for him.
The second meter is/was for the water heater.....a leftover from the days when the "all electric" house was encouraged, and water heaters were charged a different rate.
The different rate has since left us, and these second meters are disappearing as services are upgraded (usually at the insurance company's request).
The new service would be done the way Joe's artwork shows.
