1 members (Scott35), 425 guests, and 32 robots.
But why is the screw exposed on the face of the breaker? On my SqD Homeline, the hold-down kit resides under the deadfront. Is this something unique to Bryant, or did (GASP) someone drill a hole through the breaker to set the screw?
Stupid should be painful.
Looking at the second pic....I almost always ID panels in this way- though, if there is room, I am likely to place the lable on the breaker itself. It's simply a better way, I believe. The breaker is identified even if the cover is removed, and the lable moves if you move the breaker. That $30 printer has come in very handy.
Now for the bad news....the local inspectors believe that you MUST use the provided "directory." So, I get to fill that out as well. Go figure.
That is Bryant's hold-down,nobody drilled a hole in the circuit breaker.
LOL,
You'd have to be pretty keen {or stupid} to try a trick like that!. [Linked Image]
