0 members (), 1,316 guests, and 21 robots.
#101391 03/13/07 09:03 PM
Ewire88 Offline OP
I am working on a school renovation and consversion of a middle school to an elementary and the old 1930's and 50's parts were razed and the 1995 gym and class rooms addition was left standing and new parts were added to the 1995 part to make a new building. The existing boxes and conduit where left remaining ( wire and devices removed) in the 1995 part and I see no evidence of grounding pigtails and I had to retrofit the boxes with ground pigtail clips when I installed devices. Did the NEC in 1995 require metal box pigtails for bonding?
Aaron
Workgear for Electricians
#101392 03/14/07 01:07 AM
Were they self grounding devices (little brass clip on the yoke)?
#101393 03/14/07 01:19 AM
For some reason I am under the impression that 250.148 is a relatively new code. I may have read that over at the Mike Holt forum.
#101394 03/14/07 03:36 PM
Ewire88 Offline OP
I am pretty sure they were self grounding and they were spec. grade and we still have allot of old devices in our job site trailer.I am sorry that I don't know the code that well because I am an apprentice but I am still learning.
Aaron
#101395 03/14/07 07:58 PM
"Sherman set the way back machine to 1993"
In the 93 code the 250.148 language was in 250.114, pretty much the same way.
Self "grounding devices" was in 250.74 ex2
#101396 03/15/07 08:44 PM
Is this what I have to look forward to (referring to old codes as they change and I get older)? laugh
Ewire, there's plenty of "electricians" out there who aren't familiar with article 250.148. It's good that you came here to ask. Some don't even bother to do that!
#101397 03/16/07 02:02 AM
I imagine there might be some 1&2 family guys who have never used a metal box. I sure don't see them much in residential.
Yup, some day you will be telling your young guys how it was way back in the olden days when you actually had to put locknuts on Romex connectors and tighten 2 screws.
Then you will get the blank stare and the question "what was this Romex stuff"?
#101398 03/16/07 07:02 PM
Ewire88 Offline OP
On the construction site I am working on, I am glad to see everything grounded such as the metal framing beams, cable trays, plumbing and even the metal roofing. We even have a lighting protection service subcontracted. By the way here is a link to the pictures of the jobsite below. Click on the date first that says 2003-06 and the newest part you see is the part left standing and new pics should be added soon and this school should be finished early of next month.
http://www.cmw.osfc.state.oh.us/guest/photoarchive.cgi?9184+
Aaron
#101399 03/17/07 09:31 PM
just remember 2 important things for surface mounted boxes, first the receptacles must be mounted directly to the box (if you are using an rs cover then you must provide a ground tail) second you must remove at least one of those paper washers that come on the 6-32 screw (if applicable). also if the boxes are flush mounted then you must use receptacles with the spring-type grounding strap.
#101400 03/21/07 10:05 PM
Ewire88 Offline OP
I worked in the kitchen the other day and the print calls for all recepticals to be gfi and some of them are not near water and what does code say about gfci's in commercial kitchens?
Aaron
