AE-Gifts, Affordable Everyday
0 members (), 690 guests, and 10 robots.
Page 2 of 6 1 2 3 4 5 6
#100940 01/23/07 01:56 PM
I like Reno's answer. Someone may even make full spectrum CFLs.
Workgear for Electricians
#100941 01/23/07 01:58 PM
12 X 16? Those are dressing rooms- any windows? If you hang clothes in a room, does it become a closet automatically? I think the AHJ is the final answer- just ask them.
#100942 01/23/07 04:40 PM
Z
I like macmikeman's comparisons. I think I'll use that analogy for stubborn customers in the future, with your permission of course.?
#100943 01/23/07 06:27 PM
V
A little too pricey??????????
If this woman can afford two closets in a master bedroom that are 16x12 with 11' ceilings.......she can afford the right trims
#100944 01/23/07 07:32 PM
This home owner is really cool she understands that I am limted by the code on things that can be done. She just asked that there be lots of lights in all walk-in closets. If I put shower trims on these Juno can I have to install 40 watt bulbs instead of 65 watt with the baffel trims. Money is really not a concern to her, this house is about 10,000 sq ft under air. Over 6 million dollars.
#100945 01/23/07 07:47 PM
Get a copy of the plans, cross out the word "closet" whereever it appears, ans write "dressingroom."
#100946 01/23/07 10:37 PM
The size of a room does not designate what type of room it is. The prints will clearly designate the type of room. The room in question will require closed type incandescent fixtures. If she does not want the recessed shower trim type, then use your marketing skills to recommend some other type of legal fixture and maybe you will become the hero instead of the goat.
Flourescent lamps in an incandescent fixture would not pass inspection either. Any inspector that thinks he can change the code because he thinks so should not be inspecting as he is a menace to the industry.
You may not like what I have to say, but it is a free country. [Linked Image]
Pierre Belarge
#100947 01/23/07 11:57 PM
Hey Zapped, Pierre said it , its a free country. (at least for now), so go ahead and use freely.
#100948 01/24/07 12:38 AM
Semi off-topic, but why on earth does ANYONE need that big a "closet?"
#100949 01/24/07 12:41 AM
If you are going to use 6” lights use Juno IC-2 housings with 242 trims. They use 75PAR38 lamps.
http://junolighting.com/pdf/spec/G1_1_0.pdf
Curt
Curt Swartz
