Was this battery operated or line voltage operated? I understand it may really be a distinction without a difference but you won't have the possibility of 120v present with a fault. Battery equipment is also less likely to have a voltage referenced to ground (and the pool)
I do understand a capacitive "touch" pad is passive in nature with no voltage present but we deal with the worst possible scenario.
