I agree with the other responses and will add that the OLs are based directly off the motors name plate rating.
The conductors, fuses or breakers are based on the HP and the info in Article 430 tables.
The conductors must be at least 125% of the table values
I do not recall an NEC minimum size for the fuses or breakers but common sense would say at least 125% and perhaps much higher for hard starting loads.
