Gentlemen
I know that at one time this was a requirement. If it was changed, I'd like to know when? If there is a fault you can have quite an arc flash, and if the door isn't latched even when you're standing to the side the door opening with the flash will deflect somewhat off to the side. I do not think that this is a good idea.
Larry
