Aldav:
I am not aware of any NEC restrictions on a quantity of sub-panels, as long as your load calcs are OK.
'Limits' are mechanically set by the mfg.
Basically....if you have a 42 circ 'main' the most you could connect to it are 20 sub's (fed by 2-pole cb's)
