I misunderstood what you originally said Greg. I thought you meant you had the ground rod laying horizontally in the trench at 24" and were bending it up to make connection above ground. Which would mean you only had 5 1/2'ish feet horizontal.
What you actually have is a cross between 1 and 2 in my diagram right? I don't see anywhere that specifically prohibits that.
