George, that is what I am talking about. Search on "sign" and you will see a bunch you don't think of.
430.74, 430.113, 490.21, 490.22, 490.44, 513.7, 513.10, 514.11, 518.3, 540.11, 555.13, 620.3 <my mouse finger got tired> ... stuff like that. I didn't see the arc fault sign mentioned so I am sure another search word (like "signs" would find others.
If I had to summarize you need signs for GFCIs, flash hazards, backfed switches, multiple power sources or feeds (utility, generator or "alternate energy" sources), emergency systems, high voltage, various hazmat signs in classified locations, overhead cable warnings (waterways) and cable tray limitations but I am sure I am missing some.
The CD search engine is a good tool to find more. You can put together quite an eye opening show if you tracked them all down and that is just the NEC. Plug in the other NFPA documents, OSHA and state/local rules you might have to have 2 classes. ;-)
[This message has been edited by gfretwell (edited 12-10-2004).]
