Assistants are then used to hold the subjects hand on the brass plate and the experiment continues until the subject can no longer drop the wire because he cannot let go.
What a nut case!I locked on to a generator load stud once, and as the persons with me shut it off I went from 60Hz to about 5Hz before being able to let go as the voltage decreased with it.
The most painfull experiance of my life!I learned alot too! Not to do it ever again! I bet a few started swinging if they had the energy to do so after the first few times.
