Sparky, How do enforce the code if not to the letter, one persons idea of common sense is not the same as someone eles's, or do we just call you for your common sense.
Can you give an example of "much of the NEC is without a shred of rationale"
Bob
Bob Badger Construction & Maintenance Electrician Massachusetts
