We usually try to have the cabinet maker install a double bottom on the cabinets with a 1/2" space between the layers to run the low voltage cables and make the connections in. This way you can remove the fixtures and get to any of the connections.
I do have a problem with these new puck lights that Home Depot is selling. They no longer have transformers and are designed to connected directly to 120V. I have had several customers hand them to me to install and I quickly refuse. Why would UL list such a thing? I guess if you have enough money you can get anything listed.
Curt
[This message has been edited by caselec (edited 11-29-2002).]
