Well I figured the voltage drop on a load to a small barn.VD=2xKxIxD/cm and the drop was like 5 volts Here`s the question.If I measure the voltage at the wires to have the drop I`ll need the load connected and operating right?Guy here says no voltage drop unless load is running.I`ll still get some drop just for wire reistance I know.But bottom line is we figured the drop for that load and changing the load will change drop?
