Relocatable power taps are not intended to be permanently secured to building structures, tables, work benches or similar structures, nor are they intended to be used as a substitue for fixed wiring. cords of relocatable power taps are not intended to be routed through walls, windows, ceilings, floors or similar openings.
hmmmm, well this 'puter's TVSS exists simply due to lack of receptacle space, let's see....
{tips over monitor} yep. 8 items plugged in, fax, ph, yadda, yadda....
