A Concrete cutting saw has a dual voltage rated motor. Nameplate values: 120/230V. 28/14A. 1Ph. 3H.P. The building voltage system is: 120/208V. 3Ph. 4Wire. For this job we do not want to install a boost transformer necessary to supply 230 volts to the motor. We are just going to supply the motor with 120 volts. Is my drawing compliant with the Code?
http://www.geocities.com/cinkerf/saw.html.com
