I'll ditto George's reply. I've found, generally, if the capacitors been replaced the next most likely problem is that pesky centifugal switch. The part doesn't cost that much, until you buy it at the 2000% inflated replacement price, & it has ruined many a single phase motor.
Tom
Few things are harder to put up with than the annoyance of a good example.
