I still have an antique microwave (circa 1971) oven I won't part with (springwound timer lightning can't hurt). The pot metal latch broke some years ago. I super glued it back together and used that for a pattern to sand cast another one out of brazing rod material. It worked great. The trick is getting graded sand that will hold the shape. I used sifted beach sand. I made a crucible from a pipe cap welded to some #3 rebar and heated it over my MAPP torch while I tickled the brass in with acetylene. I had to clean the latch surface up a little with a file but it is still working 15 years later. My microwave detector says it is still sealing fine.
