I don't doubt that they do but a scale accurate enough to get down to a foot of wire is going to cost you.
As for weights and measures certifying a scale they are just going to laugh at you if you bring them a bathroom scale. Even if you are able to adjust it to display the correct weight it will never be repeatable and will change all over the place with temperature and movement.
