Bob, you're still not getting the joke and the fact that there is a non-existant conflict here.
Is it horizontal face up? Could it count as a work surface? Answer: No But who knows.... They could be very short.... [Linked Image] So no 406.4 would not apply....
Could the receptical be looked at as a means of disconnect, and not acessible? Or isolated? Or not accessible to wiring method? i.e. having to remove a finish to move the stove, or buried under it.
Answer: Maybe That depends solely on the stove, and IF it has access through a drawer, or other way, many do not. [Linked Image]
And I'll say this for the third time....
[/b]Otherwise its fine[/b], install anyway you see fit, so long as it doesn't clearly violate a code, or common sense...
With that Happy 4th.... [Linked Image]
