Since I'm a one man shop, I rarely get to work a job start to finish, I'm always getting called away for service calls, etc. SInce my memory isn't what it once was (I think), testing is my SOP when using cable wiring methods.
When I do my make-ups, I connect a battery & buzzer at the panel. As I make up the boxes, in order from start to finish of a circuit, I short the hot to the neutral & listen for the buzz. This has the added benefit of annoying all the other trades for a day or two.
Tom
Few things are harder to put up with than the annoyance of a good example.
