The screw shell on a lampholder is required to be connected to the grounded circuit conductor only. You are much more likely to contact this portion of the fixture while changing a bulb. If it is an outdoor porch light and you are barefoot... goodbye. Also, as in the GD example above, an inadvertant ground fault inside the motor may turn the unit on without the switch being closed.
