I also need reliable continuously submersible switches, for a model robot submarine. We have been using some IP-68 rated switches sold by McMaster ( http://www.mcmaster.com )as part# 6944K11. These have proven to be reliable, and cheap enough, but don't have much in the way of mounting options.
I've been wondering if 'float type' liquid level switches could be used, with the float removed and a different mechanical actuator in place. Many of these switches seem to be rated to several atmospheres, but I don't know the details of their operation or sealing. Judging by the pictures in the mcmaster catalog, many of these look magnet based, but when you have a well defined and enclosed mechanical system using magnets I bet they are pretty reliable.
What I would really like to buy is a completely waterproof lanyard switch, where you have a NO switch held closed by some sort of pin or clip, with the pin or clip on a lanyard, so that you can open the switch with a yank on the lanyard.
-Jon
