Hello,
This is my first time posting, but I have been reading the messages here for some time. I don't do this for a living or anything, just like to learn all I can.
In reading some messages on another message board in the links area, I read a message where a person talked about balancing his loads between phases. He said that if leg 1 was pulling 30 amps and leg 2 was pulling 40 amps, the meter would record the highest usage at 40 amps but if you were to balance the loads, the meter would record a lower overall usage. The question I have, is this the case? It seems as if the power company would want to meter all usage, not just peak.
Thanks,
Static
