The Green HCFC is used alot arround here in patient care areas with approved grounding type connectors, using the bare ground for box and insulated for Hosp grade recept. We also will use it with some ig circuits .The metal clad for more exposed area`s and alum clad for not subject to damage.All are truck stock.
