Reno, why should Peter's customer like pipe and surface boxes??? The two log homes I worked in have no exposed electrical. It takes a lot of work but can be wired like a conventional home.
Peter, the number one task you should plan on is: lots of lay out time. Start planning your circuit paths now. Also plan on being on site everyday with the building crew. Like iwire posted I hope this is being done Time & Material.
