Also, pool pump motors aren't fed with a GFI breaker, but spa's are. Why is that? If I use a GFI breaker to feed the aquarium pump motors, not sure if thats required? I'll post this in the code section too.
The Golden Rule - "The man with the gold makes the rule"
