Was back at that house today. Found that a painer decided the inside of a junction box needed a lot of paint. Cover missing and half full of paint. Took me half an hour to clean out. Also found all the ground wires in the box but one together, the one not in was the one to the panel. So I had lost the ground back tothe panel. Also the bare ground was under a neutral wire nut just touching the neutral wires stripped end. Found 3 GFCI full of paint as well. None of those GFCI were on the bedrooms circuit. After fixing all of this every thing is now normal.
Now if I can just find that painter when I have a 3 foot piece of 3/4 rigid in hand [Linked Image]
editd for spelling
[This message has been edited by nesparky (edited 02-04-2006).]
ed
