as far the resseced cans i useally just buy the whole work and use what you need to replace it becase the time to replace the safety cutoff thermal switch it will take more time than just swap the can all you have to do is slide it down and get in the Jbox and remove the bad can and hook up new can and slide it back up.
belive me it take far less time than just try to replace the **** thermal switch and less fustrating too
Merci , Marc
