I wonder if anyone has applied a meter to a long run of EMT to determine the impedance when set screws are used, and compression. I've heard third hand that a company did a test and found compression to offer a lower impedance at fault current levels. Of course I always require a dedicated EGC to be installed within the EMT anyway, but the redundancy of the raceway is helpful IMHO.
