The reason I would have to tear the foam and the duct work out of my way is because the ducts lay right on top of the header that I need to feed my 14/3 romex down, and the foam has sealed the duct to the attic floor. There is no way to get under the duct without causing major damage to the foam installation. Does that answer your question Runkle?
