Who knows what the wire is? Serice wire in tri-plex? Old single conductor wire prior to the use of tri-plex? Or is this primary wiring 7200 volts? we need picture of truck and wire as it was beore he moved it. Yes I have seen primary wire both hot and ground less 15 feet and more than 12 feet this is also in a woods with trees not to far from it.
William Runkle
