No, only low voltage. This has been a hot topic for some who would like to see the code changed to require all abandoned wiring and materials removed.
The reason low voltage wiring must be removed is because it adds to the fire/smoke load. Tough to argue that basis when you are talking about pipe and boxes. About the only thing it could be is a workmanship issue which the code does not strictly define.
-Hal
