I don't know if anything similar applies where you are, but here's some info about the
Oregon High Voltage Overhead Line Safety Act. I believe there is a similar law in New York too.
To protect those working near overhead power lines from accidental contact, the Oregon Legislature passed into law the High Voltage Overhead Line Safety Act.
The law provides that no work activities take place within 10 feet of a high voltage overhead power line until the following two requirements are met:
1. The responsible party must notify the utility operating the line of the intended work activity.
2. The responsible party and the utility must complete mutually satisfactory precautions for the activity.
As soon as you inform your local utility of your intended work activity, you’re taking the first step to insure your safety and the safety of your crew. When and where necessary, the following can then occur:
1. Coordination of work schedules.
2. Identification of temporary mechanical barriers to prevent contact with the lines.
3. Temporary de-energizing and grounding of
lines.
4. Temporary raising or moving of lines.
Failure to comply
Any party working within 10 feet of an overhead line without notifying the proper utility and establishing required safety precautions, will be held directly responsible for all financial consequences of an electrical accident. Failure to comply with this rule can carry a penalty of up to $70,000 for each offense in addition to the cost of injuries and repairs.
see:
http://www.pacific-power.com/File/File18254.pdf [This message has been edited by Bill Addiss (edited 01-31-2005).]
