royta,
You could install a thermal cutout (about three bucks) in the line and a wall mount line voltage T-Stat. This would do away with the switch altogether and if you got a cutout with a high opening temp it would be a backup if the stat gets left on.
Aside from that I doubt you will ever match that size. Is the company still around?
