What is the best way to install low voltage undercabinet lighting?
Do you install a transformer under each cabinet or can you set a transformer on top of the upper cabinet and run exposed LV cable down below the cabinet.
I'm looking at the easiest way to connect the lights with limited 120V cables being connected under the cabinet and having a wod of cable being exposed?
