If this is a temporary electric service, typcially the serving utility {PG&E?} will specify minimum overhead service-riser and underground service-lateral requirements—as long as code minimums {possibly with local amendments} are met.
I believe that non-metallic raceway for the application has been generally recognized acceptable in your region for a could of decades.
You may find applicable drawings and specs at
www.pge.com
