If its a short pole maybe 6 to 10 feet, you can dig a hole a couple of feet deep, form it with a sonnet tube and fill it with concrete, and install a conduit in the concrete so you can install your wire later. You could also check what the manufacturer says about installing this pole.
[This message has been edited by CRM (edited 02-29-2004).]
