if you want to use only solid wires on them, you can use the "standard" wagos. i estimate them to be way cheaper than the ones with the release mechanism. if you want to use stranded, i would recommend these.
the only thing you have to watch when you make changes on the standard push-ins, is not to losen the other wires when turning. i always push the others back in to assure no one came out.
[This message has been edited by :andy: (edited 01-10-2004).]
