I agree with George in the sense that I would not connect the BMW bldg ground to the radio station ground radials.The grounding system for the station also called a counter poise, is considered electrically the "other half" of the antenna and like George said is part of the antenna tuning.This is an issue to consider carefully because of the power levels(50Kw).
Chris
