We were going to do this once. Could not talk the customer out of it.
We put the GFI's in the eating area and load sided off them. Because we pipe everything here and can only use short 3/8 greenfield wips we had to feed them off other boxes that were for the major appliances.
After the granit counter tops were in and the walls were painted they changed their mind and wanted it back in the wall above the counter tops.
As soon as that was chainged they still were not happy. They did not want it the normal hight they wanted them right on top of the backsplash.
Just be worned when the costomer wants a modern home but does not want to see any recepticals you will waste a lot of time.
Tom
