Ok I know a lot of us who do old work find a lot of stuff that makes us shake our heads in disbelief or even holler out "Holy S--t!" in the presense of the homeowner but what do you do when you happen upon improper and dangerous work that was just done by the guy before you? Here's what I mean. A regular customer wants a motion light installed on the back porch (high dollar home). There's a handy box 5 feet away that was just installed by a reputable roll up shade intaller with the switches in another box. Shook my head at the 4 motor cords jammed into a romex connector which didn't have a locknut on it so the whole mess was falling out of the handy box, where it was all spliced into two more cords which were fed thru the 1/2" emt which was connected to the handy box with a compression COUPLING and to the switch box (exposed to weather) with a set screw connector. The "Holy S--t" part came when I opened the switch box to find ALL THE NEUTRALS SWITCHED!!!. There was even a switch for a pond pump in the neutral line!
Add to this all the grounding wires had been cut back and unused in each box! Of course I fixed it all before I used the circuit for the light, but I am wondering if I should report this to the registrar. Maybe they aren't even supposed to be wiring their shades themselves. This kind of thing really annoys me, especially when these kinds of installers have the notion that "wiring is simple" and "why pay an electrician?". And of course the homeowner will agree with them. What would you do?
