Thinking about getting a battery operated crimper, will only be used a few times a year, so if some money can be saved, i'd prefer to get one as affordable as possible.
Most likely will only be used for overhead service changes and irreversible ground crimping. It won't be beat up or left in the van. My guess is that it will be used 6-10 times a year.
The Southwire Maxtern version which can be had in like new condition with the D3 head is only about $600. It actually uses Milwaukee batteries.
The Milwaukee 2672 version cost significantly more (and it's the older Milwaukee model).
I realize there is a risk/reward factor that has to be applied.
At $600 if it's a Milwaukee 2672 rebrand it would appear to be worth the risk.
I also compared pics of the heads and cutting tools (i would also purchase a cutting head) and i see little to no difference other than branding labels.
Anyone know for sure if it's just badge engineering?
There is very little info out there on them, my guess is that it was just a failed partnership.
Thanks,
Joe
NJ licensed electrician
