Mine had the 16 ga pan extensions. I took the one on the right side, where the fence rides, off and mounted a router in there on a beefed up extension. Now I can use the fence and the guide slots for a sled with the saw or the router. I also drilled some holes for pins so I can cut and edge circles with the router. I have also made some jigs for different things with MDF.
