And not a bad neutral.
Some excitement today, a thunderstorm. we had a power failure today where the lights didn't completely go out. Line voltage ended up varying from 20V to 50V and at a peak of 70V. Seems lightning hit the distribution lines, and took out only two of the three phases. And I was on one of the impacted phases. Seems I was seeing power leakage thru power customers that get fed all 3 phases, and have loads connecting from one phase to another (208V). That would make a leakage path that would work its way back thru pole pig transformers back to the distribution lines and then to my pole pig.
I shut down my air conditioners and fridge, as compressors really don't like under voltages. Computer power supplies don't much like it either.
Later, once Pubic Service fixed it, saw a picture on FB of line crews in bucket trucks attending to the lines. And saw that 2 of the 3 phases were broken. One of the broken phases was the one I'm on.
To add to the fun, some LED bulbs could operate up to half their usual brightness during this event. Others didn't light at all. Incandescents showed most directly the voltage variations.
