Rob, Welcome to ECN, What sort of a switch is this and what sort of application is this being used in? I suspect that the T rating, as you refer to is the Thermal Current rating. Switches, if they are going to be used to interrupt/make inductive loads depend heavily on "AC Ratings", like AC-3 or the like, otherwise the switch contacts will be seriously damaged by the arc created when the contacts open or close.
