I know it isn't legal but I bet a plumber would say if you prime that "spaflex" and shove it in a primed male adapter with the right cement, the threads would break before the joint did. Do you see it and what do you say? I understand the NEC never mentions primer and nobody wants to screw up the look of their job with purple dye but they make clear primer (Yellow can) I can see the writing is gone. Is it time to rethink how we paste pipe?
